Aluminum housing
2x125 W @ 4 ohms of power output
2 ohm-stably
Bridged enterprise: 1x384 W @
HPAA technology
Highpass -, Lowpass and band-pass filter VCVS (= volume days control LED volume days SOURCE)
Filter for front and rear channels with bypass function
Balanced Cinch input for optimal freedom from interference
Entrance sensitivity 200 mVs - 6 V
Connection terminals gilded protective circuits against DC, overheating, short-circuit, overloading
Independent High and Lowpassfilter: Thereby both Composysteme (Highpass) know, Subwoofer (Lowpass), and Kickbaesse (Highpass and Lowpass = band-pass filter) as well as combinations of in each case two of the options mentioned to be propelled.
The two output stages are bridgable, then far more than the double achievement can be taken.
2ch mode Highpass:Anschluss to 2 loudspeaker systems
2ch mode Bandpass:Anschluss at 2 (or more) Kickbaesse
1ch mode Lowpass:Anschluss at 1 (or more) Subwoofer
1ch mode Lowpass:Anschluss at 1 (or more) Subwoofer in bridge 1ch mode Bandpass:Anschluss at 1 (or more) Kickbaesse in bridge
Technical data
RMS output power @4 of ohm: 2x125 W
RMS output power @2 of ohm: 2x198 W
RMS output power @4 of ohm: 1x384 W in bridged mode
Max input Current (@13,8 V): 33 A
Idle current (NO signal): 1.1 A
Fuse: 2x20 A
Totally Harmonic Distortion (THD):<0,03 %
SNR: > 90 railway (A)
Freq.Response (bypass mode): 5 Hz-30.000 cycles per second (in bypass mode)
Damping Factor; 420
Stability: > 2 ohms, (> 4 ohms in bridged mode!)
Input Sensitivity: 200 mV-6 V
Crossover frequencies: highpass 25 Hz-6 kHz lowpass 50 Hz-6 kHz
Dimensions: 360 mm x 225 mm x 60 mm
PLEASE PM ME FOR PRICE... serious buyer only please.. thank you :)
2 ohm-stably
HPAA technology
Technical data
Fuse: 2x20 A
Damping Factor; 420
