Works Engineering Cam Pulley/Gear, each gear is adjustable in 1' increments to a maximum +/- 10'. Our engraved timing marks are accurate to within 1 minute of a degree! With the simpler design our gears end up being lighter than the stock gears they replace.
Our tooth profile matches the OEM spec exactly for each gear we make. The outer cog section of our gears is black hard-anodized, to prevent on/wear from the timing belt. We use black hard coat because of the great contrast it gives against our engraved timing marks. The 5-bolt locking pattern is plenty secure and we use only stainless steel hardware to ensure durability. This design provides a lifetime of worry-free adjustment.
Machining for optimum component fit is critical with adjustable cam gears. Any free play between the inner and the outer sections will cause the hardware to come loose no matter how much is tightened. Our extra care in the machining process guarantees you our gears will not come loose when you follow the torque specifications in our instructions. Horsepower gains can vary widely depending on what has been done to the vehicle and how it is used. Gains from 5-20 horsepower can be realized.
Application List:
Mitsubishi 4G63 EVO 1-8
Mitsubishi 4G92/3 DOHC
Mitsubishi Lancer/Proton 4G92 SOHC
Mitsubishi Lancer/Proton 4G13/15
Mitusbishi Lancer CS3/4G18/Proton Waja
Mitsubishi Eterna 6A10/12 V6
Proton Campro/Gen2/Satria NEO/Persona/Saga BLM
Honda B Series DOHC
Honda K Series DOHC
Honda H Series DOHC
Nissan SR20DET
Nissan RB20/25/26
Mazda MX5/BP6/BP/NB6/8
BMW 318i/E30/E36
Toyota Supra/Lexus GS300/2JZ
Toyota 4A-GE
Toyota 3S-GTE MR2/Celica/Caldina
Daihatsu L200 12V / Mira Turbo
Rm450.00-550.00/pair
Works Engineering Lighten Crank Pulley the weight reduction are how we increase horsepower. Each pound of weight removed from the crankshaft is worth approximately 2.7HP and the gains jump even more dramatically with forced induction, nitrous, VTEC and increase RPM's. Only 15-20% of the gains from our pulleys come from underdriving. The diameter of each of our crank pulley is reduced up to 20%. We tailor the exact amount of underdrive to each vehicle based on factory specified accessory performance. We fully maintain all accessory output minimums like air conditioning efficiency, power steering feel, and voltage even at idle with everything electrical on in the car. There are no adverse effects from using any of our pulley versions. Bolt them on and forget about them, then just follow your vehicle normal maintenance schedule.
The second type are our crank pulley which are available in 3 versions. First is the underdrive crank pulley in standard belt layer. They drive all the accessories that were available in the car from the factory. This version is up to 20% smaller in diameter. But more important is they are 6--90% lighter than the OEM pulleys they replace. It's another reason why we do all of the underdriving at the crankshaft pulley to maximize the reduction in weight on the crank. Second are the stock diameter crank pulley. also in standard belt layout. It is designed to maintain alternator output at stock levels for car owners wit big stereos or for audio ompetitions where system voltage must maintain specified levels. For cars with superchargers it maintain the original level of boost from the aftermarket supercharger kit. Thrid are the single belt conversions. This version was designed to drive only the alternator or alternator and water pump. It is used for engine swaps or for the racer were only the alternator is being used. This version has the same percentage of underdriving as the Ultra or S version but is 90-95% lighter than the OEM pulley it replaces.
Nissan Fairlady Z33 350Z (3-Pulley set)
Nissan S14/15 (3-Pulley set)
Mitsubishi EVO1-3 / VR4
Mitsubishi EVO 7 / 8 / 9
Honda Civic '96-00' DOHC
Honda Civic 1.7 SOHC
Honda Accord 2.2/2.3 16V
Honda DC5
Toyota Supra 3.0v6 JZA80 (3-Pulley set)
Toyota MRS / Celica 1.8 VVTi
Subaru Impreza WRX ver 7/8/9 (2-pulley set)
Rm350.00-700.00/set
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website: www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: http://wikimapia.org/#lat=3.2139519&lon=101.6382739&z=18&l=0&m=m&search=win hong auto
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newfor...331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newfor...2721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newfor...s-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
