Works Engineering - Proton Campro Series Fuel Rail Kit
Works
www.worksengineering.co
949
23
Item Description:
- Fuel Rail Upgrade kits are high-performance fuel delivery units that are designed to properly supply the additional fuel needed for high boost/performance applications.
- Fuel Rail are CNC billet aluminium,large non-restrictive bore maintains maximum pressure & fuel volume at each injector decreasing the chance of cavitations.
- Direct bolt-on replacement of factory fuel rails for specific vehicle applications & allow for larger top-feed injectors to be added.
- Kit comes with all necessary fittings,block off plates & grommets for ease of installation.
Item Suitable For:
Proton Gen 2,Persona,Satria Neo,Saga BLM,all Campro Series Engine...
helo! my engine oil is now middle half ( below Max above Min ), because i finish my current 15w50, can i add using 20w50 or any grades? thanks!
