- Aug 9, 2006
- 389
- 0
- 1,516
TG9FD10-04 3.5"
Full Range speaker
- 4 ohm impedance
- NRSC White Fiber Glass cone
- Copper Cap on pole piece
- Frequency range 100Hz to 15kHz
Specification:
Re 3.2 ohm
Fs 115.4 Hz
Sensitivity 85.3 dB
Voice coil diameter 20mm
X-max 3.15mm
Le 0.024mH
Sd 36.3 cm2
Mms 2.49g
Bl 2.38
Vas 1.43 liters
Qms 2.67
Qes 1.01
Qts 0.73
Power 25W(rms)
Flange size 84mm square (98mm diameter at rounded corners)
Cut out diameter 78.5mm
Depth 38mm
Flange thickness 3.2mm
Price : RM320 per pair
Contact: 012-9142998 (Lim)
