Selling the following parts for Iswara only.
Iswara Bosch Front Headlamp-rm165(per side)
Iswara Bosch Signal lamp- update soon
Iswara Taillamp Sedan Original Proton-rm200(per side)
Iswara Side Mirror-rm25 per side( local, manual type)
Top set gasket-rm215 Original Proton( many fakes out there, wont last)
Iswara Alternator Bosch rm185. 1 year warranty by Bosch
Iswara Bosch Ignition Coil rm55 Bosch.
Bosch 80,000km Timing Belt kit set-rm60
Gates 100,000km Timing belt kit set-rm85
Dayco Timing belt kit set-rm105
Iswara water pump. Original Proton rm53, GMB Japan rm53
Iswara engine mounting front-rm36, rear-rm 48, right-rm188 (made in japan), left-rm238(made in japan)
Pro-Rallye Plug Cable 10mm Made in USA-rm190
Bosch Sports Plug Cable 8mm-rm35
Iswara Original Proton clutch cable-rm30
Iswara Exedy clutch rm155(clutch cover, plate, SKF bearing) use China/NSK Thailand bearing, u waste more money)
Iswara APM Spring front rm33each, back rm30 each
Iswara Kayaba absorbers-front rm72, rear rm43 Original. many fakes out there
Iswara Front Brake Disc(made in Japan)- rm55 each. dont use made in taiwan.
Iswara rear brake pump-rm35 each. made in Japan. dont use made in taiwan ones.
Iswara lower arm-rm50 each(local)
Bosch front brake pads-rm30
Brake shoe FBK- rm27
Bosch W8DC spark plugs-rm15(normal one)
Bosch Super4 spark plugs-rm43
Bosch wiperblades rm22
Bardahl 5w-40fully synthetic engine oil rm72, Bardahl 10w-40, semi-synthetic rm60, Bardahl 20w-50 engine oil rm34.
Bosch oil filter rm8, Original Proton oil filter rm8, cap ayam Proton oil filter rm6
Bosch air filter rm9, local OSAKA air filter rm6
Fuel filter local rm5
Castrol 80/90 gear oil-rm33
Iswara local ATF filter-rm13
Proton ATF oil rm19 each. If u get cheaper than this, confirm is fake ATF
Osram H4 bulbs rm10 each.
Please contact:
012-2908159
All prices NETT, do not bother to msg or PM me best price..
No bumper, bushes, interior parts
Please contact:
012-2908159
