HOT BITS ADJUSTABLE SPORTS SUSPENSION
* All Hot Bits shocks are mono-tube gas shocks with 46 or 40 mm pistons and are fully serviceable and tuneable
* Coil-over ADJ sets consists of performance set adjustable height shock absorbers & 60mm linear race or conical springs
* Coil-over HELP sets consists of additional helper springs for optimum shock's stroke
* External canisters provide optimum gas volume and shock stroke
* All Hot Bits coil springs are cold wound chrome silizium springs
* 1-way damping adjustable shocks come with fine 40 clicks compression and rebound adjustments
* 2-way damping adjustable shocks come with separate fine 30 clicks compression and 40 clicks rebound adjustments
* Hot Bits top pivot steel bearing mounts are optional (unless otherwise stated)
* RACE, RALLY, DRIFTING sets are available upon requests
* All ADJ and HELP sets come with shocks and adjustable height springs (60mm ID springs)
* All CS (coil springs) lowered 35mm coil springs can be ordered and fitted separately
* All SA (shock absorbers set) can be ordered and fitted separately
* RACE or RALLY kits are 10% above ADJ kits prices
* Manufacturers 1 Year Warranty
* Original HOT BITS Product
