- Oct 14, 2008
- 1,915
- 3
- 1,638
Item(s): As attached below
Price: SOLD!!! SOLD!!! SOLD!!!
Dealing method: Prefer COD (KL, Damansara, Kelana Jaya, Subang Jaya, Sunway, Bandar Utama & PJ Area)
Contact method/details: 016-351 3337
Item(s) conditions: ITEM IS USED BUT IN PRISTINE & IMMACULATE CONDITION WITH ORIGINAL PACKAGED BOX
CT4.400 Specs
1. POWER OUTPUT : 90W x 4CH INTO 4 Ohms / 180w x 4CH INTO 2 Ohms / 270W x 2CH (BRIDGED MODE) at 4 Ohms
2. POWER BADWIDTH : 10HZ TO 45KHZ @ +/- 1dB
3. POWER SUPPLY : DC + 14.4V(11-16V USEABLE)
4. SUB WOOFER : 50~500Hz@-3dB(ADJUSTABLE)-24dB/OCT
5. HI-FILTER : 50~500Hz @ -3dB(ADJUSTABLE)-18dB/OCT
6. T.H.D : 0.05%
7. S/N RATIO : 100dB
8. INPUT SENS : 0.16V~4V(ADJUSTABLE)
9. CAN TRANSISTOR
10. DAMPING FACTOR : >300
11. DIMENSION : 340(W)*67(H)*270(L)
The ratings of ABYSS' watts are very conservative, and are comfortably exceeded on its rated output of 90W RMS per channel. They in actual do about 100W~110W RMS per channel in the practical world.
"Abyss were the manufacturer for TRU amplifier until 2005... for certain reason, the contract was terminated by Abyss and TRU moves to another company to work on their amplifier...
The former model of TRU amplifier such as T1, T2, T03, C7, C7T and A Class as well as the active crossovers are most likely 95% the same as Abyss CT series, MFA Series, TB Series and A Class... the major differences I noticed is only the cable used in TRU is Kimber while Abyss using BRAX... a minor components such as resistors or maybe capacitors were modified from Abyss"
CT4.400 Specs
6. T.H.D : 0.05%
9. CAN TRANSISTOR
