WORKS - Snow Performance (Water Methanol System)
jameswwt
1,127
78
Hi,
anyone here mind to share their experience or knowledge on Water Methanol System from WORKS ENG?
Will it has a bad adverse effect on the engine?
Appreciate if anyone would kind enough to list out the Pros & Cons by using this system.
Thank you.
Pros :
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
Cons :
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
H22-C
642
74
the purpose of Water Methanol System is for cooling at high boost right ...
there is risk if the methanol tank empty and you don't notice it, you will have a blown engine.
jameswwt
1,127
78
Thanks Guys and hope more Forumers can drop in and share...
H22-C
642
74
why are you considering Water Methanol System ? you want to boost 2.0bar ? or you suspect your intake air-temp too high ? mind to share ...
sub7
152
5
Your afr can run leaner with it.
mizunori77
1,387
1,041
stock engine internals can run water-meth injection for high boost? will it damage the stock internals in the long run?
jameswwt
1,127
78
No,i have no idea actually that's the reason i created this post...
Hope more Sifu's could kindly share...
Thanks
sub7
152
5
It's like buying candy each time your kids cry. WMS is nothing new, cooler air make extra horsy. For street car I think it's wasting your $ but track/drag use it is worthy. Why not use $ for other long term potential power for our turbo car, if for street car?
More boost, more heat. Boosting 2bar for 10 sec (street) damage is so minimal as oppose to continuous 2-3 mins in track. Why worry?
jameswwt
1,127
78
Great Sharing Sub7...:proud:
EvolutionZ
5,000 RPM
5,027
1,448
can, ah tiong did it in his savvy stock engine....works well
A4XRBJ1
151
65
www.awest.de
Guys, please stop posting what you heard from hearsay, that doesn't add up to quality answers and when things are repeated they are being taken for granted which doesn't help at all.
I'm using WI for a long time in my S2000 and I'm considering it too for my Evo X here in MY.
So first stop on Wikipedia: http://en.wikipedia.org/wiki/Water_injection_(engines)
There's a lot of stuff available on one of the major makers of WI systems, which is where Aquamist comes in. They're not only the system maker which is running in my S2000, but also in Rallye cars.
Check out first their excellent website of tech articles: TECHNICAL
This one pretty much sums it up why you should have WI in your forced induction car.
Lastly, go to their forum and check inside, Evo & Subi use it a lot and you find qualified answers from people who used it and are still using it, besides you get excellent answer from Richard @ Aquamist, who knows soooo much about this topic.
Waterinjection :: Index
Just my two cents,
Andreas
jameswwt
1,127
78
Just my two cents,
Andreas
Thanks for the great sharing...
A4XRBJ1
151
65
www.awest.de
So, who's going first in installing? It naturally all depends on what you aim for, if you just want to more safety (in prevent knocking), more hp, less fuel consumption or combinations of these you still have to keep in mind that there's no way around a proper re-tune to get to optimal results.
As you're changing the mixture in your combustion chamber just adding water actually has a negative effect on your hp.
Andreas
I've been searching high and low for those transparent plastic/acrylic office blind rod which enables u to open or close the blinds. I wanna know where in KL or PJ can get it?
