Originally posted by Amedion@Mar 25 2005, 11:09
how many watts ur woofer need? go n get suitable amp first..
or u can get comp. set n 4 channels amp to power ur comp. set n bridged for ur 10" woofer...
correction :- 10" .. not 10' .. < oversize kar?
[snapback]839475[/snapback]
Yes, this is quite a good suggestion.
Another option:
1. Buy a 4 channel amp.
2. use the 4 channel amp to power your woofer and satria rear speakers.
3. Use a high pass crossover (D.I.Y also can) on the satria rear speaker.
4. Use you current line speaker out from your HU to a tweeters with high pass crossover.
Btw, your HU does have a RCA out right?
The cost:
Tweeters might cost you RM150 to RM200 depends on brand.
Wires, amp wiring kit, distribution block, fuses and workmanship need to be discussed with the acc/audio shop.
4 channel amp, depend on brand and what you actually want. Roughly around RM500 to RM600. Get the ones which is reliable and good enough. Don't get a too cheap one. Buy one that can still be used when you plan to upgrade your system once you have more money.
