Transplanted engine vs Speedometer
drummydrew
471
518
good afternoon all, this question struck me moments ago:
if a car's engine is transplanted from a lower 1.5 to a 1.8 one, how will it affect the accuracy of the meter reading on RPM and speedometer?
for example my car is satria 1.5 which has a 6500rpm red line on meter, but the 4g93 engine spec reads it has a red line of 7500rpm. how do i know if im getting an accurate reading?
AD_EG
6,328
231
Ipoh
normally depends on the sensors... when you change the engine... comes with gearbox...that gearbox got its own speedo. 4g15 and 4g93 dont share the same wiring..so ur mech surely install with ecu wiring and gb as well..so even if ur meter ori...he would have connected that speedo to ur gearbox...so should be quite accurate.
but for rpm reading...that meter wont be so accurate in terms of redline... the rpm will be accurate +- 100 lets say... but since you know ur new plant is 7.5k ....you can just ignore ur redline warning at 6500.. and rev it to 7500 if you want
in terms of accuracy it should be the same.
drummydrew
471
518
thank you so much for clearing it up for me! so i suppose its safe for me to try take the rev there if its reading properly :driver: maybe replacing to a gti panel would cure my ocd hehe
RENESIS VIII
7,063
950
Ipoh
im using a 4g93, but the instrument panel is a 4g15 one
4G15 RPM panel max out at 8000rpm which I think is still fine for your 7500rpm red line in 4G93. Imagine 4G92 MIVEC but using 4G15 RPM panel. Red line is at 8500 I think. :rofl:
drummydrew
471
518
dayum, it'll be interesting n scary to see it pushing pass the rpm meter lol!
I hardly red line too, but like bro. AD_EG said if out + - 100 still okay mah!
glad to know that it's not far off, good for reference in case im feeling heavy footed :rofl:
AD_EG
6,328
231
Ipoh
but generally hitting the redline dont mean anything without checking your power curve on the dyno.. so dont be revving it at redline thinking you're making power all the way up...always follow the feel and sound of the engine...after much spirited driving on your engine, you can feel when is the right time to shift.. and it should be earlier then the redline... usually after some serious mods to the intake, exhaust, fuelling, ecu, cam settings, and nice retune you might be able to make power all the way to redline. better yet, mivec head. hehe
30,002
I prefer to play with torque, because after max torque don't feel the pull any more.....lol
drummydrew
471
518
yes you're so right! i really cannot be sure until its put on a dyno for proper statistics. since i bought the car second hand, i have been doing minor fix-ups - replacing faulty compressor, fan belt, battery, plug cables and tires. it'll take some effort for me before getting to a proper tune up :banghead:
another question though since we're discussing revving. i recently drove my car back n forth from penang, realized that there's a grinding sound whenever i released throttle during the highway run. any idea what could have caused it? sounds like its coming from the front of passenger seat, under the hood .. :adore:
lsm1991
1,469
185
ouhh... this sounds..... very much like my issue......
1)tekan accelerator no sound can be heard (but mech said actually there was a some, very slight grinding sounds if u went very close)
2)tekan and hold rpms up, no sound
3)when rpms drop, there was a grinding sound (im my case it was pretty loud, very audible from in the car)
4)sound came from the belt area
5)sounds were not from drivetrain since it was present when testing in idle
6)interesting notes, sound only occurs when the car warmed up (my case, anywhere pass 70 deg)
if that sounds similar... (and no 4 sounds right) check the bearings, could be one of the bearings going bad.... start with the outer most belts 1st, slowly remove 1 by 1, trial and error style....
drummydrew
471
518
thanks for sharing! yes i suspected that it has to do with timing belt area and before i got to it a problem has occurred! this morning, was planning to go for a car wash n my engine started rumbling and spitting as i went on the highway, drove it to the mechanic straight. he removed my spark plugs n found one was dented, suspected the belt/pulleys aren't working properly causing the pistons to hit the valves. left my car there n came home to wait for updates :frown:
lsm1991
1,469
185
ohh crap..... interference engines, pistons hitting valves... ouch....
grinding could be bearings... but sampai the timing can go so far off? the bearing would probably have to be jammed for it to cause such damage....
-bearing grinding (but still rotating) = should be just sound, timing should not be affected
-bearing jammed = by right, depending on which bearing, i think the car would either i)not start at all, ii)u would probably hear and smell the belt scrubbing
another thing to check would be the timing belt tensioner.... if that does give, the timing belt would probably be slacking
30,002
Piston should not reach the plugs. If piston hit your valves and still can drive then you timing belt jump a few notches already....:smokin:
Hello Bros,
Anyone knows where i can find a working 2006 proton gen2 1.3 engine?
Kinda need it urgently as my current engine really koyak already.:banghead:
All help appreciated.
If you have any contacts, please PM me directly!
Many Thanks,:adore:
Danny
