the wire that goes to fuel pump gets hot!
HKS-GT2835R
1,193
83
5,148
kelate
i had a hunch, touched one wire that goes to the fuel pump and that wire felt kinda panas.
what could be the main cause? had a mech the fuel pump changed and did not supervise the installation, which i usually wud rather do myself.
was afraid it could melt something under there (external fuel pump).
and does it have something to do with the car dies every 5 minutes of idle?
gotta get pics later.
jeffayn
621
62
3,028
Klang
when ever a wire get hot (hotter than usual) , there is only 2 main reason
1- it is shorted
2- it is overload
you need to get it fix before small shorting become major one...
kayour
326
41
from my experience...bad wire connection...or loose somewhere on electrical connection
supafly555
37
1- it is shorted
2- it is overload
true. Motor over load, or bad earth. Conventional current flow (current flow from pos to neg), hence flowing from pos but not enough or too much (shorting) return to earth (negative).
but usually its gets warm. It should be as warm as your igniton power supply.
HKS-GT2835R
1,193
83
5,148
kelate
thanks for the feedback fellas! lotsa points i've noted. thanks!
The Marketplace Top Posts
Hi Bro,
I'm a GSR CK type owner which is auto transmission. Is there anyway to strengthen the auto gearbox to withstand bigger horse power? or is it interchangeable with other car GB such as EVO GB?
please share your opinion and experience. thanks~
