Stepper Motor aka Idle Air Control Valve
DDT
NEW Stock Arrived!!!
********BUMP*******
Engine cold start failure?
Engine idle stall immediate, after switched on the car Air-cond system?
Engine rough idling which is suffering the heavy electrical load in car?
Than is time to check your IACV sensor aka stepper motor for the throttle body.
The cheapest way to rescue/ correct your car idling.
Interested!!! give me a call.
Depo Dynamic Trading
Central Region Contact h/p: 012-3223583 (Franky)
email: [email protected]
facebook:DEPO Dynamic Trading | Facebook
Or PM us & we will get back to you as soon as possible.
WhatsApp 012-3223583
DDT
********BUMP*******
DDT
********BUMP*******
DDT
********BUMP*******
DDT
********BUMP*******
DDT
********BUMP*******
DDT
NEW Stock Coming Soon!!!
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
The Marketplace Top Posts
guys ! I planned to change my Evo 3 pistons to a higher compression pistons like the 2JZ pistons ..
but recently i heard that higher compression pistons are no good for higher boost..:hmmmm:
if like that why some people convert their pistons to higher compression pistons ? what are the pros and cons of this higher and lower compression piston ?:mad:
need some help here ..:vollkommenauf:
