Somebody help me
Aug 22, 2008
Hello guys....
I`m new here but I really need your advice regarding Altezza problem.
Right now I`m using altezza 6MT and facing problem when shift gear from 1 to 2 and 2 to 3...
sometime when I shift gear my car run not smoothly.(senguk2).need to release traction and push it slowly(T_T).
When I checked with shop,there said I need to change my ekzos...
Are any of you guys know what is the real problem...
I really need advice your advice...
pls help me...
AE111_SEG
1,024
180
Putra Heights
I was about to give my standard answer......Trial Tunning but just realised your are from Johor:biggrin:.... hmmm anybody here have any idea for our new friend....
coriolis
115
Your symptoms are pretty much like what I had.. car become lembap liddat rite? Did the check engine lights turn on?
Try the below:
1) clean MAF sensor (easy)
2) clean throttle body (not so easy)
Hope it will help.
Kuchiki_byakuya
Thank you for the advice.
I`m quite newbie to this thing...
can you teach me how to clean MAF sensor...
Where is the sensor location?
Clean it with what?
Greytezza
1,130
68
Truly Asia
If that is the case, my advise is to go to Mutiara Motors service centre and ask them to check for you. It will be expensive if you damaged the MAF sensor and/or the throttle body.
The Marketplace Top Posts
helo to all..
anyone know where i can cut my spring? prefer pj and shah alam area la.
not interested to buy sport spring, bcos already install heavy duty spring. higher than stock spring. make my car look like jeep now.. just want to lower it a bit.
thanks
