SO4 temperature heat up problem!!! help!~
sPoOn3838
460
5
my car temp getting worse...
what i had done to my car is;
change;
new 2 layer radiator
new radiator cap densor
new radiator fan motor
fan motor switch
new temperature switch
new termostated...
engine flush when change new radiator!
temperature gone up when the car stop, but when the car move rpm reach 2500 fan run, then the temperature drop to normal!
pls tell me what else to do!?
thanks alot to all sifu sifu...!
jasmanz
206
5
change;
fan motor switch
new termostated...
must see flow bubble on your radiator small or big bubble if not must change your head gasket or water pump .. i think la
vtecDIEhard
86
Sorry i dont mean to hijack this thread but facing the same prob
Changed thermostat, waterpump, serviced radiator.
After driving from KL to JB on 110km/h, when reach JB, temperature went up.
No sign of water reduction. Radiator fan is working.
i am clueless now. :(
sPoOn3838
460
5
i am thinking to send my car to honda mechanic?? do they do car radiator?
jingut_04
118
is it fan working?if got something wrong with head,the temp will prob even worse on running
camp
395
Bro mine got the same problem, then sent to mechanic they test my car they said that my head gasket gone, change it then the problem solve,
sPoOn3838
460
5
realy... erm.. thanks alot for ya info, by the way how much do u pay for the gasket repair.
sPoOn3838
460
5
New fan motor sure runing well, when runing its..ok temp keep stable, only when stop the car with engine runing the temp gone up... last sunday i still chassing satria NEO at seremban highway with 190 -200 kmh speed! No problem...
shiroitenshi
3,676
170
"chasing?" Isn't it usually "leaving behind?" :hmmmm: :biggrin: :biggrin: :biggrin:
Cooling systems is like that, if one of the parts clogged up (tersumbat) then it will heat up when you're not moving, even if the radiator fan is working.
if you're not burning coolant (means you need to top up coolant once in a while) then it's likely that you should change your radiator because there's sediments or something inside it that prevents good cooling of the engine.
Other parts may be involved, but a good mech should be able to tell if the radiator is more likely the source of the problem, or something else.
sPoOn3838
460
5
The Problem FIX!!!!!
its the f a r king termostate!!!!!
5 month old termostate coil spring putus !!! cause the fan switch cant work properly shit!!! this is all about the spare part shop people!
i ask for quality termostate , he give me crap thing!!! never go again that fuc king shop
SePaT
1,073
i was going to guess on that thermostate too since i kena also last 3 weeks hehehe ..lucky kena right in front of Jc resing adei ...
vtecDIEhard
86
good to hear at least solved. I thought when you said new, it is new. but it's from the chop shop.
Anyway mine still not fixed. Driving for 40kms at 160km/h and along the normal roads with gear 2 and 3, can obviously see the temp rise.
I checked the water reduction every morning, but there's no water reduction. or maybe too minimal for my eyes to notice on daily basis.
I read somewhere that if there is different meaning for the big bubble and small bubble that you see from your radiator. Mine is the big bubble that comes out. Does it mean my engine gasket is leaking?
Advice/opinion pls?
camp
395
Advice/opinion pls?
Bro, for mine, i did not check bubble, but my reserve tank beside the radiator always full when the water temp goes up,
I was there in the Restaurant opposite Summit , near the Shell
Parked my car there , then about 50 meters away ,
Could not sit outside because of Rain , so no chance to see the car
Lucky i set my radiostar vibration level to sensitive
As soon as i got to my car , one fella was running with his motorbike.
Thank god got shock sensors to detect em when he was trying to break in
Just for my Autogauge Defi look alike ka ?
Radiostar u rock.. guys better get any alarm that got shock sensor.. feel safer
