Body and interior
1. Satria 1.6 1996, Neo CPS White
2. Full Mivec Bodykit with EG6 rear spoiler
3. Recaro GTI seats, with GTI interior (door panel, carpet and center console)
4. Cap Ayam Steering ala2 Sparco, with R3 steering spacer,
5. Greddy boost Meter
6. Motec Lambda (A/F Ratio) display with Bosch lambda sensor
7. EvoII black dashboard
Engine and transmission:
1. Evo II with 4wd gearbox, locked to 2wheel
2. Stock standard engine
3. Stainless steel I/Cooler pipe, with EvoII Intercooler
4. 2.5” downpipe, with external wastepipe
5. 3.0” stainless steel exhaust piping, with 5Zigen Border Max exhaust
6. ACT Extreme Racing Clutch
7. Battery relocated in bonnet (cable laid under carpet)
8. Walbro 255lph plumb-in tank fuel pump
9. Adjustable fuel regulator (Works Engineering-Lifetime Warranty)
Handling
1. 17” SSR Type F with Federal 595 Superstreet tyres (205/45/R17)
2. Project u brake pads, with cross drilled and slotted ventilated discs
3. 2-pot Calipers (EvoII)
4. Ultra Racing Strutbar (front and Rear)
5. Ohlins 16-way hi-Lo soft hard adjustable suspension, with helper springs
6. Ohlins Pillow ball suspension mount
7. Rear Ultra Racing Anti-rollbar (19mm)
8. Front EvoII Subframe with cast Alloy lower arms and 23mm antiroll bar
9. Solid engine mounting
Miscellaneous
1. Standard boost, 0.6-0.7bar
2. Have been using car for 8 years
SMS or WhatsApp for viewing
012646470 doub
Thanks ZTH!!
Handling
Miscellaneous
012646470 doub
Thanks ZTH!!
