Satria 1.6 handbrake and brake
fadin_remorse
94
My car's handbrake does not work at all even after tightening the handbrake cable. Haven't changed the handbrake cable as yet but are there anything else i should look at? I plan to do a full service on all 4 disc brakes and change my brake hoses. How much will the cost be like?
regards
waikiki
744
Damansara, PJ
How is the condition of your rear brakepads ?
DanzEterna
15,911
3,371
www.primeperdanaclub.com
if not mistaken skimming disc brakes bout rm40-60 each,
pro rs hoses braided hoses rm200++ i think. - ask andy@rev performance
service piston kit on calipers - not sure but cheap2 only. use MMC ones.
fadin_remorse
94
the condition of the rear brake pads are bout 70% at least, but i doubt there is an issue with the piston because when i drive i can hear grinding noises from the rear itself. I am afraid the piston is jamming up...
---------- Post added at 11:28 AM ---------- 6 hour anti-bump limit - Previous post was at 11:26 AM ----------
Owh thanks for the info bro, i was intending for pro RS also as my car is old, so i thought of getting the rubbers away for braided ones
DanzEterna
15,911
3,371
if the piston is jamming up like wat happened to me.
when your car is stationary u let go your handbrakes & brakes. if your car dont roll behind means pistons will jam up soon.
fadin_remorse
94
Well for now it moves bro as my handbrakes are bad (10% working), i think the handbrake cant screw in to move the piston for handbraking. Where as the brakes, i need to overhaul i guess.
this is common problem for proton 1.6 and above with rear disc brake....
try service the rear caliper...and use better brakepad...and don't forget to put some lubricant on the cable so it move easily when pulling handbrake....
*one trick to get your handbrake grip enough to stop your car from moving while parking:: press brake paddle while engine was on and pull the handbrake in the same time...then release your foot brake then switch off your engine...tadaaaaa...now no need to put in gear while parking anymore.... :biggrin:
fadin_remorse
94
I think i will try the service method first when i get time, thank you for the heads up bro appreciate it
hey guys!
thanks for the support all these years!
i'd know, as i still get calls all the time.
anyways, thanks for calling,
please now call Richard 013-350-6561 (gosh i hope he still uses that number)
as i've resigned from Titan long ago :rofl:
