rebuilding tein HA
bajarian
17
wonder if there is any place that rebuild or service tein coilovers? is there any authorised workshop that do that in malaysia? quite a pity if the coilover spoil and have to replace, cos they are not cheap..thanks!
J101
1,304
malaysia
ure lucky dude.
n1 has just opened a massive service TEIN service centre in sunway, selangor. same thing like FULCRUM in australia.
its RM400 EACH side. that makes RM1600 for the complete. im thinking of sending mine too.
amdfaisal
4,742
20
Bawah jembatan
wow quite expensive... eh do you know if they can replace the springs of the coilovers as well? my coilovers are quite hard and the ride is quite bumpy on our ondulated hiways le
bajarian
17
tein rebuild
400 rm for one side? actualli that is quite expensive. but for those people that has only one faulty side also quite good leh. like mine, my right back shock got the squeaking sound liao. maybe its bout time to send it to n1 .. wonder ehy got the squeaking sound, anyone have this experience before? what is n1 tel number by the way? thanks!
ace79
1,082
Springs shouldn't be a prob, but if the springs you requested is not in stock, u might hafta wait for a month or so. Maybe the damping properties of your dampers are not right for the kind of roads you use? What's the current spring rate you got now?
kukuciao
99
Servicing 1 side for RM400 is better than getting another sets of 2nd hand absorber :)
Now i know a place to service my TEIN HA... hehehe
Thanks...
bajarian
17
tein
I called up N1, asked them what kind of servicing is done for 400rm. and they said, oil change seal change. But anything else that require replacement will be extra. hopefully that help my squeaking sound ...
NERV
280
i know shop can service Tein HA at Sri Kembangan. PRS SPORT SERVICE (specialist absober & spring). Pls call Mr.Sim at 012-6282927. The price for sure cheeper compare with N1. Cheers!
bajarian
17
thanks nerv, mr sim charge 100 plus to replace the seal n the oil . much cheaper then NI, and he is using all original parts from tein. YEAH!! . finally something cheaper!!
J101
1,304
malaysia
thats very cheap. even top-perfect shop charges 3XX per shox. do let us know the results koz its a steal if its 1xx only.
bajarian
17
tein
:regular_smile: well, the mr sim said that they can service all series of tein coilovers, so i guess FLEX shouldn't be of any problem, hope that help.
399
673
bajarian,
can i have the contact no & location of mr sim?
thanks in advance!
The Marketplace Top Posts
Hi all guys......i just install a defi water temp meter on my car....does anyone know how much is the actual reading for a vtec engine water temperature on meter???????:confused: cos every morning when i turn on the ignition the water temp reading already go to 30 and when after running half day the reading can reach 90 to 100...need to know in this reading is my engine cooling system ok onot.thankssss all sifu
