Rear Bushing...can DIY aaaa???
chinozie
Very Young Member... :D
Damansara
guys...just curious...
can these bushes be changes without hv to pump it...?
Halo brader...want to take out the bushes using wat? use gigi aaah?. Wana DIY can. Just buy new bushes first. open up the assembly and force out the bushes using either one of the following:
- TORCH EM! - using gas charged torch until the bushes melt, then scrape them out
- KNIFE EM! - use some sharp object to cut/slices the bushes until they are loose enuff to pry out.
- HAMMER EM! - use some cylinderical pipe of similiar diameter (same with bush diameter) and a hammer to purge them out....the hard way hahahahaha....errrr spray some WD40 to ease things up yaa
Will TRD bushes give hard/annoying rides?
I am looking for comfy setting, but not as floating as stock.
burgahahahah...thought so...:D
taking it out...maybe a bit simple...
but putting it back...will be one hack of DIY :D ...
chinozie said:
burgahahahah...thought so...:D taking it out...maybe a bit simple...
VASELINE....or KY Jelly.........
VASELINE....
better...burgahahahha...
if not "merah merah" one...
A thread every 60 seconds
