Pioneer 4Way Speaker 220W 16cm & TS-T250 tweeter
ICE -In Car Entertainment
kopiping
232
Crazy Promotion~Pioneer 4Way Speaker 220W 16cm & TS-T250 tweeter
TS-A1680S Pioneer 4-Way Speaker 220W Max (4 ohm) 16cm (6-1/2")
** Max. Music Power 220W
** Nominal Power 50W
** Wooder 160mm
** Midrange 40mm Dome
** Tweeter 16mm Dome
** Super tweeter 10mm Dome
** Impedance 4 Ohms
** Sensitivity 91 dB/W (1m)
** Frequency Response 30 - 30,000Hz
** Gross Weight 1.39kg 5Ib 7oz
______________________________
TS-T250 Pioneer Dome Tweeter 150W Max (4 ohms)
++CLEAR SOUND++
++GOOD QUALITY++
Component speaker for car stereo Flush/Surface mount 25mm (1") Dome tweeter
* MAX. Music power 150W
* Nominal power 50W
Cutoff Frequency 7000Hz with 6dB/oct
Hight pass filter (HPF)
* Size 1"
* Impendance 4ohm
* Sensitivity 92dB/W (1m)
** Frequency Response 2,000 - 30,000Hz
** Gross Weight 0.5kg 20.9Ib 9oz
speaker with tweeter
PROMOTION ONE SET IS ONLY 160
location old klang road , PJ , SUNWAY
PROMOTION VALID TILL END OF MAY
contact 0163355573
PIC:
http://forum.lowyat.net/index.php?act=Attach&type=post&id=223112
http://forum.lowyat.net/index.php?act=Attach&type=post&id=223110
whuster
154
bro where the place to cod..can i install this speaker into my satria??
ayidy
46
plse pm me ayid---0193424434......i want one set....is it 2 speaker with 2 tweeter?....
The Marketplace Top Posts
Can anyone recommend a place where I can balance my crank pulley?
Some part of my pulley's edge has chipped off. To balance it off, I drilled a small hole on the opposite side of that chipped part but this is just a very rough estimation. I do not know how much weight should be drilled of.
Can anyone recommend where I can balance it and how much it cost?
Thanks.
