Guys,
Lately I have noticed that my car will overheat if its at standstill for more than 15 minutes.
I had the A/C on and within 15 minutes I could see my temp rising over the halfway mark and gradually going higher. (Farkkkkkkk!!!!!)
If I switch off the A/C, temp will go down. If I am moving, temp will go down as well.
I went to some mechanic here in JB and he told me that my radiator probably is clogged, so he said need to "service". With engine ON, the damn radiator hose is empty!!!!...as though nothing is going through. So I assume sumbat lo..So ok la, he dismantles the radiator and does the sevicing. Frankly I am not too sure what he did, but he he said he wanted to unclog it. Draining the water, I saw that its all rusty and Teh O in colour. :blink:
Anyway, he puts the radiator back in. With engine running can see that the hoses are full of water and looks like its moving. Then, after 1 day, kanasai......overheated again!
So whats the problem ar?Cant be thermostat rite? A/C fan running and all!
He has a "dual layer" radiator that he says I should plonk in, but it needs to be modified as the hose positions are not correct, basically not a Toyota AE101 rdiator la..... Advisable?
Help.......!!!!!! <_<
