NewBie to Perdana V6
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
Thanks Bro.. Really Helped a lot..
maybe I just throw my Auto and move to Manual..
For the Standard V6..
What's the best Gear box?
Any specific model?
Can the standard V6 be upgraded by after market parts?
since u have rm10k to spare, keep rm5k for the engine & another rm5k for your gearbox just incase it dies.
for manual tranny on v6, u could opt for code 232(shorter ratio, clutch plate is 8.5") or 312(longer ratio, suitable for v6tt clutch plate is 9")
make sure its complete
1.gearbox
2.gear lever complete with cable
3.3 pedals, or 2 pedals enough (brake & clutch), some shops only provide the clutch pedal only, then u gotta cut your brake rubber pedal.
4.upper & lower clutch pump
5.clutch & flywheel
above could costs u rm4.5-5.5k
there are only minor upgrades for v6,
1.custom extractor - costs rm800-1k
2.crank pulley
3.cam pulley
4.aluminium radiator
spawn_net
147
27
528
1.gearbox
5.clutch & flywheel
2.crank pulley
3.cam pulley
You Guys are the KING of V6.. :top:
Thanks guys..
Btw the short ratio and longer, I assume short ration is better for a NA?
Cant wait to start the project.. hihi
Auto tranny can sell for how much? Mine done 200,000km, I assume superbly works well as I religiously do a gear oil change every 20k km..
DanzEterna
15,911
3,371
3,213
PJ
yes, shorter ratio suitable for na, longer for turbo.
if use shorter ratio gbox on v6tt the 5th gear syncro will wear off.
auto tranny no value, maybe trade in rm500-600.
Thanks guys..
Is bro. Danz, he is the King. We usually also page for him on V6.....:driver:
Maybe bro (DanzEterna) you should start something like a 1 stop centre for car mods and especially V6.. im curious what car do you drive now? must be superbly pimped...
The car he drives now, he looks like a pimp if he wear dark glasses..... faster cabut......hhahahhahahahhahahhahzahaa:rofl::rofl: :rofl: :rofl:
humongousgravy
189
Seremban
Bro isn't the 312 the shorter ratio gearbox and the 222 or 232 the longer ratio aka "gearbox termenung"? That's what I remember reading here.
hex999
378
57
528
Quite sure the 312 is short ratio, previously owned one and 100kmh, RPM i think was around 3500 or less on the 5th gear. If your gonna top spend a lot of money on your perdana, make sure you get a decent anti theft system on it, 220 was around 7000+
This picture is taken with the 312 GB
the ratio is similar to this vid
https://www.youtube.com/watch?v=9jcjjYDwEAo
The Marketplace Top Posts
Lets take for example a Wira 1.5Gli it comes stock with disc in the front plus 2pot calipers (i think) and drum brakes at the rear.
So if was wondering if wanna get better performance ..
1) Transplant ABS from a compatible Lancer set.
2) Upgrade the rear to disc also, upgrade the front to bigger ventilated disc, and upgrade calipers from 2pot to 4pot (for example).
I think (1) would be the obvious solution if doing an engine transplant as everything would be compatibe but if it wasn't a...
