H4i wanna know what is the bulb for the lagi best lagi power myvi headlamp
That's rubbish. If it's an engine it's tunable. Just a matter of how much money you have.Is Denso IK22 iridium spark plug suitable for myvi 1.5? And is it true that 3SZ-VE engine has very little tuning capability as compared to K3-VE engines. :wavey:
Nope. It probably shares the same gearbox as the AlzaHi guys, Myvi 1.5 manual gearbox and the myvi 1.3 manual gearbox is same?
Drum brake with ABS? And in a perodua? R u sure bro?myvi front and rear is also with ABS.
Not suitable. You need IXU22 spark plug. the spark plugs for 2007 onwards Myvi 1.3 and Myvi 1.5 has a physically smaller spark plug.Is Denso IK22 iridium spark plug suitable for myvi 1.5? And is it true that 3SZ-VE engine has very little tuning capability as compared to K3-VE engines. :wavey:
Thank you for the clarifications ! for NGK cross reference i guess it would be DCPR7EIX right correct me if i'm wrong and btw, what's ROI? aha. Sorry for the noob questions.Not suitable. You need IXU22 spark plug. the spark plugs for 2007 onwards Myvi 1.3 and Myvi 1.5 has a physically smaller spark plug.
3SZ-VE has longer (weaker) conrods compared to K3-VE, if you turbocharge it guarantee the conrods bengkok. N/A tuning is a waste of money, the ROI is very low.
I suspect the 1.5 autobox ratio is similar to the 1.3. You should wonder why Perodua publish gear ratio for Viva but none for Myvi :)
I'm wondering if IK20 is compatible to 3sz-ve? I've seen some using that instead of ixu22. Not sure what's the diff..Not suitable. You need IXU22 spark plug. the spark plugs for 2007 onwards Myvi 1.3 and Myvi 1.5 has a physically smaller spark plug.:)
I have it installed. So far so good no rattling sound caused by the bar and the ride back is a little firmer. Has been using it for more than 7 months now.Has anyone tried installing the UR rear lower bar ?
Does it produce any rattling noise/sound after using it awhile ? And mind sharing your experience/feedback particularly on this bar ? really appreciate it.
Eibach? It has good feedback so far:hmmmm:errmm..what brand of lower spring suggest? :stupid:
Depends on what you want/need. If you want performance then quite a good setup I've tried which doesn't cost too much would be GAB lowering springs with absorbers like IMP Comfort or Propex. As the GAB springs are quite stiff, you may feel your ride is harsh on our roads but you'll get quite good handling.errmm..what brand of lower spring suggest? :stupid:
