HI,
THIS IS BRAND NEW COIL ON PLUG (C.O.P) SET UP FOR EVO 1-3 / VR4
KIT COMES WITH 3/16 INCH THICK T6061 ALUMINUM PLATE THAT IS CUT PROFESSIONALLY BY WATER JET ,4 BRAND NEW COILS,CONNECTORS,WIRE SEALS,PLATE GROMMETS ,ALL NEW ALLEN HEAD BOLT HARDWARE ALL PRE WIRED .
PLATE IS HIGHLY TRIPLE SANDED AND POLISHED FOR MIRROR POLISH LOOK!!!
ALUMINUM IS LIGHTER AND BRIGHTER THAN ANY OTHER METAL.THAT IS WHY IT IS USED ON ALL AUTOMOTIVE HIGH PERFORMANCE PARTS LIKE (BOV'S,WASTEGATES,FUEL RAILS,PUMPS,INTERCOOLERS,PIPING,CYLINDER HEADS,VALVE COVERS ETC YOU NAME IT...
1.C.O.P ELIMINATES YOUR OLD WORN COIL PACKS AND SPARK PLUG WIRES.
2.YOU WILL NEVER HAVE TO REPLACE SPARK PLUG CABLES AGAIN
3.YOU WILL FEEL MUCH BETTER THROTTLE RESPONSE
4.GET MORE STRONGER ,LONGER SPARK THROUGH OUT THE WHOLE RPM RANGE.
5.HELPS WITH DETONATION/KNOCK ON HIGH AND LOW BOOST LEVELS.
6.ENGINE BAY WILL LOOK MUCH MORE CLEANER AND IT WILL HAVE A SHOW LOOK.
7.SPARK PLUGS WILL LAST MUCH LONGER.
8.GAIN HORSEPOWER .
9.YOU WILL NOTICE MORE MILES PER GALLON.
10.IDLE WILL BE SMOOTHER.
Chain 0193185319
8.GAIN HORSEPOWER .
Chain 0193185319
