Metering for Turbo engine
wfc31
138
wfc31.fotopic.net
Bro,
just wonder what are the minimum require metering stuff for turbo engine and its function?
1. Turbo timer --
2. Boost meter --
3. Oil temperature meter --
any else and pls tell me which one is a must to install, thanks..
lan evo
3,063
129
5,163
for me
1:boost
2:water temp
3:exhaust temp
i found out water temp very important
with those extra meter u can monitor ur engine condition more easy
wfc31
138
wfc31.fotopic.net
actually exhaust temp meter & oil temp meter are inter-link, they serve same to monitor engine temp, once oil temp raise, that mean water temp also raise.
so, i will prefer oil temp meter.
alien
2,564
5,138
kuala lumpur
agree..
since water temp..can always refer to the engine temp gauge in the dash..
altho not so accurate..
do u guys think it's risky sumone uses juz a boost meter for an L5 and nuttin else?
..stock turbo though..?
Joeker
Walking Dead
3,580
62
Jinjang
Basic set of gauges for a turbo engine,
Boost = manifold pressure
EGT = Air Fuel ratio efficiency.
Oil press = Engine bearings and turbo bearing getting correct oil press, not too hi, not too low. Oil pump status.
Oil temp = The turbine heats up the oil much higher and rapidly. Oil temp too hi, low viscocity, engine damage.
Water temp = Engine coolant temp. and combustion efficeincy.
But with the rampant thefts of car accesories especially performance accesories going on, I think not a good idea to have all these guages.
Boost and EGT is already sufficient.
how would you reckon that a car which can speed up double of an average car but being thrased just like any other cars on the road
when we was asked to do some stone chips touch up, we nearly faint seeing how badly this was thrashed so called detailer - and regularly wash by them as well
severe marring and swirls
swirls...
