luxman CM4000 specification
Continuous effective capacity
50W × 4ch (4Ω) 200W × 2ch (4Ω, MONO)
Input sensitivity and impedance
NORMAL (LOW) 0.5V/20KΩ (HIGH) 2.0V/3.1KΩ
DIRECT0.5V/25KΩ
S / N ratio (rated output)
(IHF-A correction, input short, DIRECT) 107dB or more
Total harmonic distortion
20 ~ 20,000 Hz (+0,-0.2dB, DIRECT)
5 ~ 100,000 Hz (+0,0.2 dB, DIRECT)
Frequency characteristic
Damping factor
(4Ω, 1kHz, DIRECT) 100 or more
Battery voltage
DC12V
Power consumption
(1.6A, no signal) 19.2W
(30.0A, 4Ω, rated output) 360W
External dimensions
Mm (height) 480 (width) × 302 (depth) × 76
Weight
9.5kg (body)
Auxiliary equipment
RCA inputs, balanced input terminal (CM-2000, CM-4000),
Speaker output terminal, remote terminal, ground terminal,
Battery terminal, fuse, volume adjustment,
Mode switch, input level,
Input level set switch,
Input selector switch,
Indicator (OPERATION, PROTECTION)
