Hmmm.. in all these posts, no one seem to mention the obvious.. that pulleys, pistons, etc. present parasitic DRAG for engines, but the flywheel is an ENERGY STORAGE DEVICE.
The function of the flywheel isn't to siphon off a portion of the engine's rotational output for other purposes, e.g. aircond and power steering pumps; neither is it a reciprocal mass that contributes to the frictional loss as a part of the power generation process, i.e. pistons.
Flywheels help to STORE the rotational energy of the crankshaft. Lightening the flywheel = reducing stored energy. Yes, your engine's spool-up feels "lighter", that's because less energy is being stored and hence it takes a shorter time for the engine to "fill up" the flywheel with kinetic energy. However, it's detrimental to regular driving because once you lift your foot off the pedal, the crankshaft loses its angular momentum quickly.
Lightened pulleys on the other hand actually reduce engine loss. Lightened pulleys + unlightened flywheel = easier to conserve engine crankshaft's angular momentum + lower rotational inertia. Lightened pulleys + lightened flywheel = harder to conserve engine crankshaft's angular momentum + lower rotational inertia.
For daily driveability, lightened pulleys + unlightened flywheel should be the proper combo.
Lightened crankshaft pulley may give similar "feel" to lightened flywheel, but the underlying principles are not exactly the same. Hence, lightened pulley =/= lightened flywheel.
Bump: Hmmm.. in all these posts, no one seem to mention the obvious.. that pulleys, pistons, etc. present parasitic DRAG for engines, but the flywheel is an ENERGY STORAGE DEVICE.
