Remember I posted about Modifying My 1990 Saga Na...afta sum thinkin, I thought dat itz beta to transplant an engine straight..I need your help about what engine can masuk my saga?? Gsr boleh masuk ar?? How about other engine models?? Thank You!!
dev said:if u want turbo vr4 good choice 4 saga, n if N/A mivec 1.6 =).... all the best on ur decesion
where can get this 4g91 carb 1.5 dohc engine ar? wat kinda shop and location..?Yong_5290 said:gsr 4g93t sure is rm 6000k for halfcut edi...
but y wanna go tat much...the chasis might not be able to take it also...
if u insist on turbo engine...look for 4g61t which is a more direct swap for ur car...
if u have low budget...just get a 4g91 carb...1.5 dohc...not bad also...n also cheap
saga is an old car...not to good if put too powerful engine...playaz7 said:OK! Now I planing to get a 4G93P 1800cc engine..full set except gearbox la..can that engine fit into my saga?? Chasis can take it or not? How about the gear box?? can I use my 1500 magma gearbox?? Need sum tips on this!! Focus On Me la!! hehehe
engine can fit in....but i HIGHLY RECOMEND u change together wit gearbox..no point keeping an old magma carb gearbox in ur car....useless......giving u problem only...playaz7 said:My Car upgraded d stability and all ade...now am using sports spring n new absobers 15" rim and all la...juz wanna know if the engine can fit into my car and will I b able 2 use back my gearbox for dat engine...My current engine is 1500cc magma carb...
