How to remove damaged wheel nut?
benccckl
62
Hi frens, any idea how to remove damaged wheel nut? because mine broken half way when I tightening it. so I tried several ways to unscrew it but the nut damaged I'm scared to cut it with cisel because it'll damage the thread.any alternative?
ken yeang
6,000 RPM
6,617
1,327
grind out the nut....bit by bit. Then chisel off the rest. Anyway, damaged bolt can be replaced. cost less than RM100.00
Or if you have access to oxy-torch...just vaporise it...bit by bit, Be very careful though, ask the sifu at mudguard shop to help. I've seen a couple of sifu doing that...
koie587
1,001
try send it to welding shop...ask them to weld a steel rod to the screw and open it...
sphiroth
103
5
Some shop have a special tools to open it. Looks like a normal lock nut opener but with several different sizes and they will pick one that fits the damaged lug nut.
nuno
148
same case like mine,2 times happen to me,both k speed lug nuts btw what brand is yours?
koie587
1,001
usually happen to aluminum lug nut?...
TS using what normal or racing nut?...
ken yeang
6,000 RPM
6,617
1,327
if the lug nut is stainless steel, then you cannot weld to a steel rod. The welding will not stick...
RONIN
378
6
same happen to me.. my SSR nut loose his grip.. don't worry, tyre shop got tools and know how to unscrew that... but must be patient..
benccckl
62
thanks bro, i went to tyre shop & they remove it using special tool
The Marketplace Top Posts
Adrian Newey's latest creation is capable of beating the formula one lap record at Suzuka by a staggering margin of 20 seconds.
Red Bull Technology's top-secret X1 Prototype, tested around the Japanese circuit in virtual reality by Sebastian Vettel, was created for the new PlayStation game Gran Turismo 5.
Newey's challenge was to create a virtual car for the game's November release not bound by any set of...
