[HELP] on AE111 SRS Airbag Light
CorollaGT
80
5
Malaysia
The airbag indicator didn't shut off after engine started. I already disconnect and reconnect the battery terminal for 5 min to reset the ECU. But problem still occur? Any boby can help on this?:cry_smile:
Thank you
runx608
51
Rawang
check ur SRS airbag cable....c whether it is unplug or loose liao .... cos it wil cos the light on ....js my experience hehe.
CorollaGT
80
5
Malaysia
TQ runx608 for your replying
I already check the SRS impact sensor [yellow connector] on the L/R seat belt modules. It is seen OK no loss. But, i haven't check the dashboard yet. Any idea where is the spiral cable located?
TQ
CorollaGT
80
5
Malaysia
Found error code 31 = Airbag center sensor malfunction from friend diagnostic scanner. Center sensor stuff located on lower part of dashboard. Hope it is a cable connection problem only.
feralee
54
Cheras
happen to me also
what had u done?
Cronixz
34
same problem here.... but just left it... looks cool!! but not sure if its risky
CorollaGT
80
5
Malaysia
New 12130 SRS ECU will cost RM 2,300+-. I manage to get chop shop unit from mudah.my. It cost RM 170- only. I been searching for 3 years plus for this rare stuff, you can try your lucky on online auction etc, ebay, mudah.. or look for fellow who brought AE111 halfcut for engine conversion.
swift2510
66
13
It's a broken spiral cable. Located behind the steering. You also will lose the function of the horn when this is broken.
feralee
54
Cheras
wow
so expensive
for the time being
i already unplug the airbag device at my steering, scare suddenly deploy
im planning to mod my putra standard enjin to racing cam n i have no idea bout it..need advise..cost?? need change piston?? wat cam suits??? thx a lot..
