halfcut B16A from civic EK4 not power as B16 from Integra?
sPoOn3838
460
5
halfcut B16A from civic EK4 not power as B16A from Integra?
a stupid question to ask!!!
is that true?
got a foreman told me that the original halfcut B16A EK4 is not power as original B16A integra??
i am confuse!!!
By the way found a B16A halfcut from year 92 integra rm4000 is it worth to buy? with that value?
Opt-ion
667
If I'm not mistaken 92 Integra is already B18... correct me if I'm wrong
sPoOn3838
460
5
ya,.... got B18 and B16 too... even DC2 model still got B16 under the hood!
just not common in malaysia!
SataniC
Old Is Gold
1,885
81
Subang
no no...1989 - 1991 DA series integra is B16A...1992 and above is DC/DB series and only come with B18C and B18CR for type R...theres no b16 for DC2 mate....for da6 halfcut the price is around there....got mine for 3.8k....
minivan
1,793
121
BBBangi/KL
Yeah... logically if u say a b16 from an integra, immediately the DA6 comes to mind... so, if thats the case, its a 'VTEC kecik'.... EK4 deffinately 'VTEC besar'... so u do the math on which is more powderful... unless ur pomen refering to an auto EK4...
prodigy
2,786
Besides, when he's trying to push you the older B16A from Integra, he'd probably bullshit a little. You can refer to the older threads of chasis and engine codes and check the horsepower ratings.
barracuda
247
last batch of DA series using Big V but its still came with clutch cable
EG's using Big V with hidraulic clutch..
udengfahlawi
1,350
12
putrajaya
is that true?
i am confuse!!!
which foreman told u that?...give us the workshop name....so can add to the "Never To Go There" list...heheheh....
SePaT
1,073
mush be phua chu kang
sPoOn3838
460
5
OK MY mistake!!
anyway pls answer my question if you can !
thanks
hattech-v
12,756
12
Seri Kembangan
www.avantech.com.my
power wise as long as its B16A big v shud be same. as what being quoted by honda.
with 2K different, if u doing the transplant for ur EK then better get the EK4 hafkat... u can use the dashboard, meter cluster, ABS, Airbag and most of the engine part quite close to EK9 type r parts.. n everything is pnp.
A
achor
Guest
wait! dc/db series has a lot of version maa.... got first got FF n 4WD ^_^ usually dc with E-DC2 comes with B18C. (if not mistaken la). but E-DC1 should come with a 1.6 twin cam engine (probably ZC?). not even vtec if i'm not mistaken. not sure whether got B16A from DC series or not. if ur computer can display kanji n all the japanese characters, n u can read japs, why not try honda's website?
Oderf
1,070
www.zerotohundred.com
yup...hattech is right...go for EK4 if u r installing it into EK....to me, i only dun like it that i comes with OBD2 wiring...means hard to play ecu 're-chip' thingy ler...the rest all fine since it's the same B16A...parts are all interchangable...
Opt-ion
667
Yeah hat-tech actually I tried posting this tread before but felt really helpless, doestn't find any directions. Pls anyone cud give some opinions.
Appreciate from Hondarian
carnage
183
bdr baru sentul
my 5 sen, slight diff in gear ratios often been exaggerated as
xtreme diff in power... but im surprised that even some sifoo hondarians
agreed with our fren's pomen
SataniC
Old Is Gold
1,885
81
Subang
aaaa?opinion?its simple math...if you are driving an EG better get EG halfcut cos u can fully utilise everything...same goes to if u r driving an ek or a dc....i have no problem with rechip...im using the big V da halfcut and using chip meant for EK....so far no prob...not sure how or why :P
A
achor
Guest
from wat i know, OBD II ecu doesn't mean that it can't use performance chip. but if u've got an OBD I ecu then want to use OBDII, the wiring part can cause u headache. that's why some people who drive EG prefer to stick to EG halfcut only. but if u've originally got OBD II wirings (EK n newer models), i don't see why it can cause u problems. but there r peeps out there says that it's already hard just to put VAFC to an OBD II ecu. that means EK type R n DC type R. i sincerely don't know. better refer to an EK owner. Satanic says he doesn't have any problems ^_^
Opt-ion
667
J101 said:
opinions about what exactly may i ask?
I was trying to find out where is the best place to source for complete halfcut with wirings correct ECU that EK match wif EK n not Eg mix wif Dc. that cud coz so many short circuit...
SataniC
Old Is Gold
1,885
81
Subang
usually halfcuts comes with everything ie. corrent wirings and correct ECU...its the shop where you do the transplant that plays an important role...ive seen a fair share of shops who are too farkin lazy to redo the entire wiring...all they did is snip half your original wiring and reconnect with the new one from the halfcut...this is the main cause of transplanting headache....again.....get a proper shop to do the job..not some under the tree yah....
kent75
972
Cheras, KL
DC2 and DB8 is with B18C1 GSR(Black Top @ 185bhp) , n DC2-R is with B18C5(Red Top @ 200bhp)
If B16A, then comfirm DC1 or DB6...
The DC and DB series' 1st batch is 1993, so if u say it's 1993, then I assume it's a DB or DC..
If u r driving EK, then i think u'll rather get EK4's B16A with LSD...
Cheer~~
Oderf
1,070
yeah.. EJ/EK go for EK4/EK9 halfcut.... if u want bigger displacement can always drop in some b20b or b18c block.......the complete EK halfcut transplant is more important so they will look like an ori EK.....i've installed vafc in my OBD2 ek4 engine....no problem....easy job...i even remove it myself...just refer to the user manual.....
Dear friends ,
I got to know from my nephew that in Penang there,s a guy who could provide engine diagnostics service or ECU configuration /testing to make sure that your system are in good running order. He also sell this product but quite expensive about RM15k lo.
His diagnostics service are charged between rm 50 to rm 80 dollars . So u guys that resides in Penang could use his service .
His name is Sham
phone number 012 4879699
