Fuel saving gadget
kenny1980
15
Hi guy ,
Been driving coupe for 2 years...and fuel will become more and more expensive Need some advice for any fuel saving gadget ( grounding , voltage regulator , pivot spark and so so ) ... Do advise onto the matter ...
kenny1980
15
Honestly would like to ask u guys .. what the lowest fuel consumption u ever had ... for me is rm 100= 500km
Daniel Lee
2,950
4
Kenny,
that means you're doing RM0.20 per km.
My average is RM0.185 per km with light right foot.
ken3182
304
Kenny,
Guys,
My problem even worse. RM 100 = 350KM only. Not too sure whether is the AF sensor anot. have to sent it in to garage to check.
ericmivec
202
haha,den i better than Ken, mine is RM100 = 400KM, consider not bad as a heavy bodykit car, wakaka
ken3182
304
eric,
How was the performance after you change to manual? got change ECU anot?
TCSIM
1,178
Mine also RM 100 for 500+ km for a stock standard car.. But grounding wires definitely helps on the performance
kenny1980
15
just install the pivot voltage regulator and grounding .. hope it helps
TCSIM
1,178
yea.. it helps! I m using some ciplak brand of volt stabilizer and grounding wires.. might change to pivot in future...
Daniel Lee
2,950
4
Guys,
You can try sending your car to Hyunmal in Glenmarie for diagnose.
They have proper equipment there.
TCSIM
1,178
Sim,
how does those voltage stabilizer and grounding help?
The grounding wires help to distribute the negative charge in the engine bay more evenly.. The few bolts and nuts that holding the engine are not sufficient to distribute the negative charge from engine to car chasis and other parts. Grounding wires help in this way..
Electrical wise, sometimes we turn on head lamp, signal light, audio, bla bla bla.. This will lead to a not-so-stable spark in the combustion chamber.. This is where voltage stabilizer comes in..
