there are bunch of them at the wokshop since people not only change the engine, but also the dash board. so anyone has crack dashboard and want to replace should be able to get it cheap.
Sure bro I will PM you guys when I need it... for the dash board I think I'm still gonna use back my ceffy wan... I need some $$$ for the blow off valve 1st scared turbine really blow off... hahaha :)
Last Saturday i successfully integrated the semi automatic mode to my E46 converted with 1JZ with A340E automatic transmission. The car's gear changes can be controlled with flip of the gearknob. Everything else is perfect except for the input signal. I noticed that downshift signal is just right but the upshift signal is a bit retard, like there's a delay of 1 sec before the gearbox respond to shift.
From what i gathered, the stock ECU does retard the upshift signal for whatever...
