RM 10 mil / amount of pyramid level X Downliner + top tier = Total d**K scored
Aiyo like that CB hoi far lor..
Ok, I'll share with you guys how typically they calculate their commission. Those on the top will laugh all the way to the bank. The company? Needless to say.. millions and millions.
In fact mlm scam is nothing but money scam-it is the transfer of money from the bottom to the top, and once your downline stop recruiting your money stop. Or once your downline don't upgrade by paying more your money stop as well. One shocking truth is that
the outcome is known by the introducer..someone must lose and lose until foolat.
Ok, enough being said, here's the typical calculation on a 40K joining fee. For easier calculation I use 10% as a general guide. But in fact there is known payout
higher than 10%.
Direct Recruitment Bonus: 10%
Simple calculation, once you recruit you get 4K.
40K x 10% = 4K
Pairing Bonus: 10%
What is pairing? In a Binary Plan there is always the
'left leg' and the
'right leg'. Assuming you have 002 and 003 underneath you. They both invested 40K each to join. Once you pair them together 002(left leg)-003(right leg)=40K you'll get another 10% x40K=4K from there.
40K x 10% = 4K
Pairing commission doesn't ends here, the above is calculated on when the 'agent' first joint. Agent 002 and Agent 003 will definately have their own agent as well rite?
So from Agent 002 will split geometrically 002(1)-2-4-8-16-32-64-128,...
From Agent 003 will split geometrically 003(1)-2-4-8-16-32-64-128,..
Now, all the underneath agent's sales is considered Agent 002's group or Agent 003's group sales, and when in 2nd run you pair them together again what happens?
Supossing both 002 & 003 have a perfect pair, both have 128 agents underneath them, please look at the sum:
Agent 002: 128 x 40K = 512,000...you pair...Agent 003: 128 x 40K = 512,000
512,000:512,000 x 10% = 51,200
Matching Bonus: 10%
Matching is the calculation on each successive generation. The bonus is given from the sales generated by each generation and this is the most explosive earning power in any scamming mlm.
Usually max 5 level is given. Anymore level the organizer will go bust!
Agent 002 and Agent 003.........................................................................is your 2nd generation.
004-005; 006-007.....................................................................................is your 3rd generation.
008 009 010 011; 012 013 014 015..........................................................is your 4th generation.
016 017 018 019 020 021 022 023; 024 025 026 027 028 029 030 031..is your 5th generation.
Please take note each agent from 004-031 is capable to generate their own member tree as well. Each also capable of generating their own group (1)-2-4-8-16-32-64-128,...
And you have the 10% bonus for 5 levels! I'm lost to how to calculate here..but the amount run into millions.
There are many attraction strategies to drive the sales, coupled with the each successive run, and the company gives prompt and on time payment..the effect is simply contagious, and ppl are going
crazy. Thus it snowballed..
The Company
There is only one clause that safeguard the company from going bust, its called
'flushing'. All the sales will be flushed or reset to zero '0' sum on the midnight of the 30th or 31st of each month. And what I listed above is a perfect pyramid where all the spot being filled up and running simultanously; in reality it is very difficult to achieve. That's why the company being saved from paying the complete commission.
Ok coming back to the 10M girl. She does not need to get scored by so many..die lar like that. She just need to be scored by one (satu sudah cukup ma..)..most probably the owner of the organization itself...it's a 2-way process, so she being put in the
prestigious 001 position..!
Disclaimer: Again this write up does NOT teaches you to practice and break the law. Do it at your own risk.
