CEPSA HIGH MILEAGE 25W50 (5Liter)
High performance lubricant designed to combat the aging effects of engines with over 100,000 km, with special additives that help to eliminate oil leaks caused by the wear of the engine itself, allowing its useful life to be extended.
Applications
o High performance oil, recommended for all types of private vehicles, especially those of high mileage, under normal or severe conditions (in urban conditions or demanding road conditions).
o Indicated for those vehicles, which due to high mileage, have a high oil consumption.
o Suitable for turbo and normally aspirated engines, especially those overloaded by high temperatures.
Performance
o Conditioning additives for gaskets which help avoid oil losses.
o Exceeds the protection requirements petrol or diesel engines that recommend an API SL category oil or less.
o Very high detergent/dispersant power due to its ACEA A3/B3 level
o High oil oxidation protection (its thickening), also protection against sump and piston deposits as well as lacquers or varnishes on the cylinder sleeves.
o Great high temperature thermal stability, allowing it to withstand without deteriorating many kilometres at high sump temperatures (150 ºC).
These values may be modified without any prior warning.
CEPSA Lubricantes, S.A. · C/ Ribera del Loira, 50 · 28042 Madrid
Normal Price: RM120.00 Raya Promo RM90.00
PWP, if buy 2 only +RM50.00
2 Bottle only RM 140.00 (Door to Door Delivery Inclusive, only Peninsular)
Applications
Performance
