Carburetor Section
Nowadays mostly fuel injected car dy......those who have used or gone through carb, will drop in.....:biggrin:
Thanks, wow looks like no one visit this thread now.
So is this baseball bat thing, should I ask someone to put it back?
My Saga is the one with manual choke. Do you mean that this cold rod retract by itself (auto?) during cold start or when I pull the choke?
When you mention retract, do you mean during cold start the baseball bat move out or move in deeper to the carb housing?
Without this cold rod right now, is my throttle plate in normal position when I am driving (warmed up)?
Initially, the rod was fully retract when engine was cold. The throttle plate was partially open to increase rpm during cold start,
If you notice, there's two water hose connected to the cold rod assembly... When water temperature increases. Water pressure also build up and gradually push the cold rod outward around 8MM. And pushing back throttle plate to reduce opening of throttle plate . Thus decreasing idling rpm around 700 rpm.
I have a saga lmst, where can I have the carb retuned or even rebuilt? someone who is good in tuning especially. From klang valley or KL be fine
New mechanics don't do Carb. If You want, can try my mechanic, Hoong Seng Autoworks, 22, Jalan TPP 1/16, Taman Perindustrian Puchong, 47100 Puchong, Selangor Phone: 03-8062 4185. Old school mechanic from Carb time. He did my Civic 1st Gen, Accord 1st and 3rd Gen, even my Weber mod. Mr. Fong 019-3315475
Thank you for the reply. Will give him a call.
A thread every 60 seconds
