microtech lt8, perfectly tuned by joshua thiran of millennium motorsports asiawat ems dat engine is running on?..
whoaaa 350whp for daily drivin...400hp on crank..how you counter torque steer?? semi slick for daily ka?? drive shaft can tahan arr if you carry 4 person when boosting.. very kaya arr you...on the std td05h 16g, 272ponies on the dyno dynamics. on the t3/t4 it was making around 350 on the same boost level. den, the intercooler was changed to a bigger (shiny, lol) unit and boost was lowered to 1.3bar and the engine made around 360mustangs on the same dyno. the car is pulling harder now because the torque increases a lot on the new tune @ 1.3bar
---------- Post added at 04:09 PM ---------- 6 hour anti-bump limit - Previous post was at 04:07 PM ----------
wow, unbelieveable.....what cams u using? if u dont mind to tell...on the std td05h 16g, 272ponies on the dyno dynamics. on the t3/t4 it was making around 350 on the same boost level. den, the intercooler was changed to a bigger (shiny, lol) unit and boost was lowered to 1.3bar and the engine made around 360mustangs on the same dyno. the car is pulling harder now because the torque increases a lot on the new tune @ 1.3bar
Well saidAt least have to Re-Operation its for inspect againts the Oldies Internal Parts...It's the flow + pressure. Boost pressure is just a precompression of the air before it is recompressed in you cylinders. BUt of course, different fuel have different thermal property.
IF u have a high pressure but small flow turbo, example u boosting at 2bars with TD04L on an E3, the turbo chocks before 4krpm. When u boost 3 bars with the turbo, still the air is insufficient to fill your cylinder due to low cfm.
Example, I have my BOT with TD04L once tuned to boost 1 bar. Now, I'm on GT2560R boost ing at 0.6bar and I have white plugs.... Heheh....
Hmmm... good good....
True, we don't know how the engine was driven before us... E3 discontinued in 1996. Which means the newest E3 engine available is 13 years back.
However, if u take a look at kedai potong... Almost 90% of the Evos are kept standard and low mileage... They're fine...
Back to the thread starter... To my experience, it's safe to boost 1.2-1.3. bars with stock internals if TUNED WELL... The ignition timing is a little aggressive and higher CR compare to its precedor E1-E2. So, it's more risky to boost hight.
If u can avoid lean AFR and premature detonation, then things will work fine.
hehehe your so lucky laa..not like me..foot everyday heavy mine previous car also 385whp wira body..eat driveshaft 3 times..gearbox pecah 1 times, 1 year 2 times change tyre daily boost 1.5bar..1.7bar if encounter subaru or evo.. fc very high coz bigger injector .:proud:...lasty my EMS got stolen + summone by JPJ coz engine not endorse sad and bored too much money burn..until my car sold...now time for berjimat cermaty kaya eh? drive shaft is still holding so far.. using road tyres, sime astar, cheap and tahan lame, bawak macam biase no hal kot
20.5 cents per km??..dat's very very save!..my 93t boost 1.2bar with stock turbine(using emanage) only manage 24cents/km..thx xtremeleo !!
ehdrian, a well tuned engine wouldnt consume too much fuel...my previous setup 1.5bar 370whp with an average of 10kms/litre...am happy with that fc
yes, about 21 cents per km...a tank of rm85 good for 400kms on average...if urban only is about 350kms, long distance can reach almost 500kms if driving 100-130kmh20.5 cents per km??..dat's very very save!..my 93t boost 1.2bar with stock turbine(using emanage) only manage 24cents/km..
Somthing to support ur statement... Tunning and hardware, which is more important... Brain vs muscle...wit the std gasket, it lasted for 2years kot, and then the head terangkat. upon opening the engine head, we found dat the gasket wasnt burnt pun, so it was the headbolt. changing to new cometic metal gasket and arp bolts, the compression was raised beyond the std spec. dis engine has been running high boost, high compression for around 2 years and counting and still performing good.
trust me bro, its not the boost dat kills engines but rather poor tuning
---------- Post added at 03:06 PM ---------- 6 hour anti-bump limit - Previous post was at 03:03 PM ----------
apart from the arp bolts and cometic gasket, everything else is bog std. in fact, the engine was running fine before changing those two things @ 1.7bar of strong boost
