Buying a Perdana
NeuroOne
WFH
2,074
181
Putrajaya
no worries la.
if standard auto V6 or RVR turbo auto, driveshaft buy new one brand ODM.
this one pretty good, warranty 2 years or 50K km, price around rm230/240.
i use this 3 years already no problem.
auto gbox, if dont have ATF cooler, install it.
make the ATF cooler hose go straight from gbox to cooler to gbox again.
dont let the hose go into the bottom of the radiator (originally it goes into the radiator)
usually after 150K km, the auto clutch will wear out, so that is the common problem.
send the gbox for overhaul and new clutch pack.
another thing, watch for white smoke.
usually the valve seal wears out, so need to do top overhaul.
if severe white smoke, then maybe piston ring out, need to do overhaul.
The Marketplace Top Posts
Hi guys,
Could you help me on above problem? i have change to 4G63 N/A, but the engine cannot running smothly and i suspected from control sensor map. i have change it already but didnt get any effect. i didnt know what to do anymore. the engine cannot running smoothly when i turn on the air cond and regarding from that, the engine also can shut down without any signal...
Regards
wira3319
