hi everyone, i'm gonna use b16a head and b20b block. so any thing should i do before i can start doing it. my main concern is the modified hose to the vtec switch controller. i'm worried that my vtec will mulfunction please help
I got a problem here. My aircond compressor running just only about 10 sec
then cut-off.that's why my air-cond not cold enough.it getting worse in
hot day. i went to the air-cond shop.had service the cooling coil and top-
up gas, problem still not solve. then the mechanic assume my ECU got
problem bcos our air-cond system control by the ECU and not separated as
other cars. i'm thinking if ECU got problem, sure CHECK ENGINE warning
light sure on. Anybody got this problem to...
