I have one unit Tire Preasure Monitoring System (TPMS), BRAND NEW in the box. I received it as a gift from my uncle but to bad I already order other unit. This is a RACING SPEC version as it will transmit the data in every 3 second.
Item(s): Orange Electronic TPMS
Package includes:
* 1X Wireless receiver and display unit (Carbon Fibered Look)
* 1X Cigarette lighter power cable (can be permanently installed using same cable minus cigarette adapter)
* 4X Wireless transmittor and pressure/temperature sensing module
* 4X Tyre valves
* 4X Screw for tyre valves (Nylock screws)
* 1X Manual
Price: RM650 firm
Warranty: 1 year by the manufacturer
Dealing method: Prefer COD but can add extra RM30 for nationwide courier
Location of seller: Klang Valley
Contact method/details: Contact directly at 012-2126547
Age of item: Brand New
Item(s) conditions: In the Box
This is what TPMS do..
Overview
Orange's Tyre Pressure Monitoring System (TPMS) acts as an early warning device monitoring your vehicles tyre pressure and temperature in real-time, full time. Once the Orage TPMS senses a problem you will be alerted, enabling you to react instantly.
The in-vehicle electronic display is clear and visible, even in direct sunlight.
Features
* Tyre pressure monitoring in real-time, every 3 seconds, updates the display every 30 seconds
* Tyre temperature monitoring in real-time, every 3 seconds, updates the display every 30 seconds
* Clear digital display presents the 4 tyres pressure and temperature in turns
* Audible and visual alerts when tyre pressure or temperature exceed set thresholds
* RF Wireless
* 7 Year battery life - military spec (-40 deg C ~ +125 deg C)
* Easy installation and setup
* No external antenna required, invisible antenna (Patented) built into pressure sensor that sits inside the rim
* "Auto Location" feature allows for regular tyre rotation without having to remove sensors
* Durable and vibration resistant
* Accurate in all climates and locations
* Suitable for passenger and 4X4 use
* Sensors are housed inside the tyre on the rim, so not risk of sensor damage and is not visible on the outside - can't be stolen
Specs
* Battery Life: More than 7 years, under normal conditions
* Storage temperature: -40 deg C ~ 125 deg C
* Operating temperature: -30 deg C ~ 105 deg C
* Operating humidity: Max 95%
* Operating frequency: 315 / 433.92 MHz
* Pressure monitoring range: 0kPA ~ 535kPA / 0Bar - 5.35Bar / 0psi ~ 77psi
* Pressure reading accuracy: +- 4% in normal environmental conditions
* Transmitting power: Max 5dBm
* Power supply: 3.6V Lithium battery
* Modulation: ASK / FSK
* Sensor sample rate: every 3 seconds (Continous)
* Sample data transfer: every 30 seconds (Continous)
Extract from Leisure Wheels magazine:
THE LEISURE WHEELS TOP 10 NEW ACCESSORIES
All about the air
The latest technology in tyre pressure monitoring systems was recently released by Taiwanese company Orange Electronics. Called the TPMS, the monitoring system offers advanced tyre safety, reading tyre pressures and temperatures every three seconds, and transmitting this information, for all four tyres, to the driver's LED display every 30 seconds, 24 hours a day. The TPMS offers an operating battery life of more than seven years, can operate in a wide variety of temperatures and even has an audible alarm for pressure changes.
Package includes:
* 4X Tyre valves
* 1X Manual
Price: RM650 firm
Overview
Features
* RF Wireless
Specs
All about the air
