BMW Engine Timing Tool Set (N42, N46)
Car Culture
jaspersoong
70
- Suitable for the following applications:-Camshaft installation and removal
- as well as removal and installation of the inlet camshaft and carrier
- assembly / Valvetronic System
- Easily accessible operating instructions including cross references to
- original part numbers
- Spare parts optionally available
- Clear arrangement of tools in high-quality plastic case with foam insert
BMW:
- E87: 118i / 120i ¡ N46 engine
- E46: 316i / 316ti / 318i / 318ti ¡ N42 engine
- E90 / E91: 318i / 320i ¡ N46 engine
- E85: Z4 , 2,0l ¡ N46 engine
Hey guys,
There is oil leaking around the head. A lot! Brought to two workshops and both say just need to change valve gasket seal/rubber. One of d workshop told me that oil also leak onto the timing belt so that got to change too.
My question is, I noticed that the head was leaking after a late night high rpm run so how is it possible that the valve gasket seal only needs to be replaced? I feel like the problem requires a top overhaul and replacing the valve gasket seal.
Is this...
