Blitz Mirror Drive, SBC/MMD i-color, DCIV Turbo Timer, R-Vit/Fit
Blitz sbc i-color
RM3100
Featuring a 65,000 colour display, and a screen that can be flipped so that it can be mounted in different positions, the SBC i-Color employs a twin solenoid design for ultimate boost control up to 2.5bar. The head unit can display a multitude of readings including boost, power and torque, speed and rpm. With the relevant sensors fitted (available seperately) the unit can also display oil/water temperature, oil/fuel pressure, and air/fuel ratio.
Blitz MMD i-color
RM 1750
[font=Arial, Helvetica, sans-serif]Available as an upgrade to the SCB ID I, II or III, the MMD i-Color consists of the head unit and wiring harness from the SBC i-Color, and enables the controller with all the same features. Utilizing the existing solenoid, the MMD connects directly to the wiring loom and therefore converts original equipment into the awesome boost controller/Power Meter ID combination.[/font]
[font=Arial, Helvetica, sans-serif]The MMD's screen is brightly backlit and uses 65,000 colours. The display options are hugely varied, from analogue style gauges, 6-function readouts, and graph style plots.[/font]
Blitz Mirror Drive
No control unit needed.
Boost White/Carbon Face RM580 (mechanical) RM740 (electronic)
Exhaust Temp White/Carbon Face RM860 (electronic)
Oil/Water Temp White/Carbon Face RM680 (electronic)
Fuel/Oil Press White/Carbon Face RM840 (electronic)
Blitz DTT DC IV
RM500
Limited units available..
PM or call 016-2928677.
Blitz sbc i-color
RM3100
Blitz MMD i-color
RM 1750
Blitz Mirror Drive
[font=Arial, Helvetica, sans-serif]The most distinctive gauge to have been produced by Blitz, the Mirror Drive meters are brightly backlit and have a mirror face when the vehicle ignition is switched off. A full range is available (boost, temperature, pressure, and exhaust gas temperature) and the gauges are 60mm diameter and come with either a carbon or white face.[/font]
Blitz DTT DC IV
RM500
