if the bottle have gas inside means its your compressor at fault, if no gas could be punctured cooling coil or condenser.
If too bubbly also means not enough gas. Should run near to liquid form....if the bottle have gas inside means its your compressor at fault, if no gas could be punctured cooling coil or condenser.
I will check it out tomorrow..My main suspect, compressor! If not that one it could be the receiver you told me about...Means you air con running but no cold? Need more accurate feedback.
Main thing is the compressor, is it running? Magnetic clutch activated to run the gas.
Enough gas or not, see receiver drier whether gas bubbling or near liquid form
If not enough gas then got leak some where
If enough gas, see fan speed fast enough or not
Other then that will be the expansion valve at the cooling coil
Does the receiver drier ice up?
Wiring or Magnetic clutch problem...What if the air cond compressor kick in and off, in and off? Compressor faulty?
Mine say my car is on stationary. On gear D, when I turn on the air cond, legs on brakes. The car will jerk in front.
Then the sound of switch on and off sound from the air cond.
Got to get Fong to check then.Wiring or Magnetic clutch problem...
He couldnt check whether the car is jerking. So after done all, when I about to leave it starts again when I switched on the air cond. So I showed him.Last Saturday still not done?
Car always act perfectly when at the mechanic.....hahahahaHe couldnt check whether the car is jerking. So after done all, when I about to leave it starts again when I switched on the air cond. So I showed him.
Then will do at next service since was late adi.
no wonder mechanics cars looks old, but really dependableCar always act perfectly when at the mechanic.....hahahaha
Like bringing own son or daughter to clinic. Reach clinic when doctor say need injection, suddenly no sick alreadyCar always act perfectly when at the mechanic.....hahahaha
haha, yah! unless he/she really sick.....Like bringing own son or daughter to clinic. Reach clinic when doctor say need injection, suddenly no sick already
Its in already..sorry for the wait!Ts when are u going to give us an update on ur car? :D
Newbie
