Alpine SPX-177A Type X Component & MRV-T320 V12 Series Power AMP
ICE -In Car Entertainment
tctho
8,000 RPM
8,006
Interested please call 012-2881509. Loc Kelana Jaya
sold
Item bought new and just remove from my car and still in excellent condition
Alpine SPX-177R Type-X 6.6” Component System
• Bass Engine Ready
• Custom Cast Aluminum Frame
• Airflow Optimized Dual-Flare Pole Vent
• Integrated Spider Landing & Heat Transfer Plate
• Low Loss Rubber Surround
• Hemp Fiber Woofer Cone
• Phase-Integrated Dustcap
• 26mm Soft Dome Tweeter
• Ultra High Quality 2-way Crossover
• On/Off Axis Compensation
• Bi-Wire Input and Selectable Tweeter Attenuation
• Swivel-Flush/Swivel-Surface/30¯ Angle Tweeter Mounting
• Custom 17mm/16mm Adapter Plate
Tweeter Features:
• Flush, Surface & Angle (W/swivel) Mounting Kits
Woofer Features:
• Curved NRSC Diaphragm Shape
• Low Distortion Magnet Type
• Semi-roll NBR Surround Material
Alpine MRV T320 V12 Series Power Amp
• 80 watts RMS x 2 at 4 ohms
• 110 watts RMS x 2 at 2 ohms
• 220 watts RMS x 1 in bridged mode
• stereo or bridged mono output
• Tri-Way capable
• Bass Engine® features:
• variable 15-400 Hz high-pass/30-400 Hz low-pass crossover, 12 dB/octave
• variable Bass EQ (0-12 dB of boost at 50 Hz)
• MOSFET power supply
• STAR Topology (minimizes internal noise and prevents ground interference)
• speaker- and preamp-level inputs
• oversized power and ground connections
• gold-plated screw terminals
• top-mounted controls with cover
• detachable front cover
• blue power LED
• 9-3/4"W x 2-1/2"H x 8-1/4"D
waihung82
48
what is the best price for the Alpine comp?
As u stated , this is Alpine SPX-177R Type-X but i see the picture and it is showing there is SPX-177A...
SO which one is it actually?
tctho
8,000 RPM
8,006
Item sold. The speaker is SPX 177a not R
where 2 get stuff for DIY grounding...
such as 8awg cables n others...
sum say can get in pasar rd..
but im nt sure which shop...
pls help...thx:)
