ACL / King Engine Bearing
andysky5
33,386
55
1,648
ACL / King Racing Engine Bearing
ACL Engine Bearing
The unique combination of design, metallurgy and engineering come together to deliver what drivers expect from high performance Trimetal engine bearing.
Designed to withstand higher RPM conditions, ACL Race Series Engine Bearing are available for many of the popular 4, 6 & 8 cylinder applications and feature:
  • High strength overplay plate with reduced thickness for improved fatigue properties
  • Hardened steel backs on all rod bearings to improve the support of the bearing lining and assist with bearing retension in the housing
  • Increased crush for improved bearing retention
  • Elimination of flash plating on the back of the bearings to improve heat transfer through the bearings and to maximize the grip between the bearings and its housing
  • Increased eccentricity to compensate for bore distortion at high rpm and to assist in the formation of hydrodynamic oil films
  • 3/4 grooved Main Bearing to optimize bearing load carrying surface area and oil flow to the conrod bearings
  • Tight consistent wall tolerances to help you maintain consistent clearances
  • Enlarged ID chamfers on bearing adges where required to accommodate large fillet radius on performance crankshafts
For more information click on the link ACL Race Series Performance Engine Bearings
Price : rm450 onwards
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at Rev Performance @ No.7, Jln PJS 11/24, Bandar Sunway (1st Floor, on top of F3 Racing) or Send by Postlaju.
Operating Hours : Monday to Saturday ( 11am - 7pm )
CLICK HERE to check out my other sales Item !! :burnout:
https://www.facebook.com/pages/Rev-Performance-Auto/194149357289701[/QUOTE]
The Marketplace Top Posts
Im holding back the Rim which is 17inch. May I know which is the budjet and suitable brand sport spring for it ? My aim is 1.5 / 2 front, 2 Finger rear. Please suggest it. If you guys hav any shop recommended, i can drop by and purchase it. Zmax and Kimex.. Which is lower? Which is softer(Naik Kuda on uneven road) ?
