chaf.song
From Facebook
FTZone got dyno machine too... can contact raymond...
any GSR-ians here running on RON95...?
assuming stock ecu....
It could be something else. How can so many error codes? Knocking also got error code? Or the knock sensor is not fitted la? Btw, no ready made solid mounting for Waja/CK yet ler.. all have to manually pump in.the CK model... fitted in Waja (that day met you at your shop, asking for mounting).
Those codes that I can remember : AFS, Knocking, TPS, .... the rest forgot dee.....
Hi,FTZone got dyno machine too... can contact raymond...
Tried running on RON95 but the engine pings. Using stock ECU with stock turbo and running 0.68 bar of boost. Am suffering now with a Walbro fuel pump. With careful driving and not going above 100km/h I can get 520km on a full tank. But do a bit of speeding and I will lose about 100km of my mileage!FTZone got dyno machine too... can contact raymond...
im running on RON95 with std boost. no pinging, unless i switch fuel (not intended, normally shell, but once a while pump in petronas, the ping came in during boosting). my full tank only can get 450km.. roughly, it's like 10km/litre.Tried running on RON95 but the engine pings. Using stock ECU with stock turbo and running 0.68 bar of boost. Am suffering now with a Walbro fuel pump. With careful driving and not going above 100km/h I can get 520km on a full tank. But do a bit of speeding and I will lose about 100km of my mileage!
since i used to own a bmw with s14 sr20det, i can confirm that the s15 t28 is a ball bearing turbo..Hey people, I'm considering to change my
Evo turbine to Nissan silvia S15 turbine...the reason to change Coz it is causing pretty lot of turbo lag to me...then foremen recommend
to take silvia s15 turbo claiming the turbo is a ball
bearing turbo from Garrett which is GT28 AR60 is the codename...sifu sifu
Is that true???
same bro...I got the same problem thats why Im looking for a better turbo or smaller turbo if problem still cannot solvedalso just changed my stock turbo to td05h, lag.. boost starting nearly 4k rpm, but it difficult to go over 7k rpm, izt the exhaust muffler affected? or stock gsr intercooler problem?
do you mind to share the code with us? After I did a few survey. Fellow friends based on their experience told me that if I'm having turbo lag on a TD05 turbine then I will suffer the same with T28 ball bearing turbo as well...since i used to own a bmw with s14 sr20det, i can confirm that the s15 t28 is a ball bearing turbo..
when searching for 1, be sure the turbine code is exactly for the bb version. cause t28 also have the non-bb turbo...don't get tricked by ppl claiming the ar60 t28 is always a bb turbo. do a search in google and u'll have the right info in no time..
only custom made is available bro...dont have ready stock in Malaysia market at the moment yet.hi sifu-s! driving a lancer 1.8ralliart turbo..they call cs5 in singapore..
juz wanna ask 4g93T GDI got ani turbo manifold to change?
thinking to swop for TD04...heard need to change extractor to fit?
Not that surprised as all your mods increase fuel consumption.520km on a full tank?..wow!..i'm only able to get 120km for half tank of fuel, with slightly bigger snail+walbro+evo injectors+after market t/b+tuned emb..
Yes, I exclusively use Shell fuel too. I guess the main difference in mileage is also because I manage to get on highways a lot. So I can cruise at a steady speed. But what's the use of having a turbo-charged car if you're constantly driving at low speeds? :stupid:wailup said:im running on RON95 with std boost. no pinging, unless i switch fuel (not intended, normally shell, but once a while pump in petronas, the ping came in during boosting). my full tank only can get 450km.. roughly, it's like 10km/litre.
add injector and fuel pump do helps bro...but you need to have tuning lah...without tuning no matter how big capacity fuel injector you install the car also wont fly...hi..GDI engine add injector and fuel pump got use?
GDI hard to mod.......
