I have a 1.8 Mivec for sale...jus done around 10000kms wif dis engine....below are the engine specs
1)4g93 block wif mivec head(usin the 4g93 pistons cuz duwan compression to be too high....daily use car)
2)mivec throttle body
3)mivec intake manifold
4)mivec injectors(it shud be 240cc same as 4g93 but mech told me its better however fuellling is fine)
5)4g93 wiring harness
6)custom adjustable fuel regulator(the one which uses the original bottom part without meter fuel set at 2.8bar) if u wan the meter i hav can giv it to u as a package
7)customize gearbox ratios 1st 2nd and final drive 4got wats the ratio but good for pickup and highway cruising
8)9inch mmc clutch set and lightened flywheel from 4g93t
9)ngk power cable wif ngk platinum spark plugs js changed last month still new can take out n see
10)hotbits 4-2-1 extractor(the 1st batch wan dis wan never leak like those local hotbits nowadays) thermowrapped
11)2inch piping for wira body wif centre bullet ended wif ApexI N1 muffler
12)shiftlight to activate the mivec (the brand is stri sth lidat but it served its funcions well) acts like mivec controller u can activate mivec at wateva rpm u like but its best to activate at 5200rpm to avoid any damage(dun mess wf mitsubishi mah)
13)autogauge air fuel ratio meter for sum monitoring purpose
14)timing belt from supra 1jz stil new can c the toyota word stil
all seals are fine no leaking found
PUSPAKOM papers all available fully LEGAL engine not curi wan
reason for selling:upgradin to TURBO!! location in penang SERIOUS buyer can cal me up il bring u for a test ride
PRICE is RM6500 negotiable SERIOUS buyer call me or sms at 0164547727 do not pm as i seldom com online
PICS will be uploaded soon..... :baring_teeth:
