4g93 engine vibration
stalepot
5
arlington
sup all- got a 4g93 sohc out of a 93 eagle summit dl. replaced head gasket and timing belt. got timing belt on marks lined up start car all is good but engine vibrates at idle. Read in manual that silent shaft could be 180 off causing this but what i not understanding is how to verify this or how to fix it seems to me that the tensioner is what needs to be adjusted but it just bolts into the block so i confused. help please. thanks in advance.
boosook
378
Shah Alam
try taking ur machine to ur mech..ask him to check on ur engine mounting..i think that is y it vibrates when u idle..hehehe hope this helps abit! :biggrin:
boyzone
2,669
engine mounting or either ingition timing too advance only :D
kktham
92
chances is you need an engine mounting change. try to get it from half-cut, more lasting.
Just wanna ask.. is there any difference in fuel consumption when using open pod air filter and stock standard air filter? Which is higher? What if i dont use the air filter pulak? Help me sifus...
Thanks!
