Originally posted by ae92levin+Jan 14 2005, 04:11 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (ae92levin @ Jan 14 2005, 04:11 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-TireSmoke@Jan 13 2005, 19:24
cool, thanks for the info. just wanted to find out cause the toda valvetrain kit cost 2500. so before i go out and spend the money, i thought i'd find out first.
that's what i thought. with std valve spring it should be ok, but it would wear the camlobes faster.
i would be more worried about valve float, screwing up ur valve and shims. not so much about the cam lobe. [/b][/quote]
well, regarding the valve float issue, I just noticed JUN's performance cam for MIVEC only had clearances of
0.1 mm for intake and 0.2 mm for exhaust
while our 20v stock has
0.2 for intake and 0.4 for exhaust (all on the thinest side)
So, I think if we up the cams duration, together with lift and valve springs, may be should reduce the clearance also.
for the reference, I think need to refer to formula atlantic built process. But I don't recall seeing valve clearance specifications.
can some one confirm?
Since I did my valve clearance and have 2 lower than spec and there's no problem, and still more compared to JUN's performance cam, so I've been thinking to reduce all exhaust from 0.4 to 0.3 :) hahahha I wonder got any REAL difference or not?
hhahahaha, greedy chin :)
