Hi vr2turbo,
I'm looking for rims spec around 17x8JJ +30 to +35 range and the car is running on adjustables (no more big bulky spring seat like the stock). Yeah another thing to consider is the inner fender. Never really came across my mind :) Thanks for reminding.
Btw, you're running on VR4 as well right? Mind if I ask hows the traction like running on 17"? Whats your tyres spec and what tyres are you using?
Normal 17" are +42 offset and most comes in at 7 to 7.5J only. 8" got to scout around, especially +30 offset. Try asking those bigger tyre shops.
Yup, have to check inner fender as you have gone 40mm wider.
My stock Super Saloon last time was 185/70R14, then I tried 205/50R16 because at that time 17" was very expensive. After a few years, 17" came in cheaper and 16" have less choice then only I switch. The tyre size I am using is 215/45R17, and have kept to this size because is the correct conversion, the size is the most common, plenty of tyre choices and cheaper the 225/45 and 235/45R17. Some VR4 club mates are running 235/45R17, of course looks better but will take up some pick up power and will aquaplane more easy. Traction is good enough for me as I use as every day drive. Of course different tyres gives different performance. I have used the likes of Falken ST115, Yoko ES100, Falken FK452, Yoko S-Drive, GY GS-D3, Toyo T1-R, GY Asy, Blue Streak Stiletto, GY Asy2 and GT Radial Champiro HPY. All give different feedback, be it better in wet, dry, aquaplaning resistance, handling, ride comfort and so on...
