need help bout cam.....
[email protected]
246
Brand: Tomei
Part: Camshafts, (1) Intake (1) Exhaust
Duration Intake: 260
Duration Exhaust: 260
Lift Intake: 11.20mm
Lift Exhaust: 11.20mm
Part #: 143042
Engine: NISSAN SR20DE S14,S15
hello to all sife...would like to ask wherther can use this tomei cam shaft on my stock engine....?do i need to change valve spring or cam chaft adjuster..??thankz
slide_it
238
10
anything above 270 would require change of springs.
256 and 260 are drop in cams from tomei
Md Ekal
91
6
508
Gurun/Kedah
Brand: Tomei
Part #: 143042
I want to know la.....
If this set kaco a/cond o not???
n how bout engine idle???:hmmmm:
Nats autoparts
411
20
please check on the web page to determine the cam spec..
if pon cam doesnt need valve train change
if pro cam does need
please follow guide base on Tomei Web page to guide you the way of modding you engine..
enjoy!!
When will the bigger cc hybrid cars available in our local Msian market?
Do you think the bigger cc versions will be just as reliable as the current small cc ones?
Will it be costly and pricey?
Can anyone with news or info kindly reply.....:confused::love:
